The result of “uvm_config_db #(int)::dump();” shows the following in uvm_config_db.
drv [/^uvm_test_top.env.my_agt.*$/] : (class $unit::my_driver) ?
Question 1: Why uvm_config_db can’t find the “drv” from the global task (glb_wrapper)
as shown below ?
task glb_wrapper(input int addr, output logic[31:0] read_data);
static my_driver h;
if (!uvm_config_db#(my_driver)::get(null, "uvm_top_test.env.my_agt.*", "drv", h))
`uvm_fatal("glb_wrapper", "Cannot get drv !!!")
Question 2: Compilation error that RHS is not a class if the following is used in a global task
(as shown above) ?
h = uvm_top.find(uvm_test_top.env.my_agt.drv);
JT
