I modeled an AXI slave memory as an object with methods for reading/writing. How can I access these methods from a sequence for preloading, data checking, etc? I tried putting the memory handle into the uvm_config_db/uvm_resource_db and getting from the sequence without success. Is this possible? If the resource_db is the proper way, how exactly do I set/get? Is there a better way to model a slave memory so I can access from both components and sequences? Thanks in advance, Steve
