I have some set of register and I am using default reg sequence to check power on reset values for those register.
But I need to disable uvm_compare for some register, So I am using following method to disable some of the register
uvm_resource_db#(bit)::set("REG::",reg_model.reg1.get_full_name(),"NO_REG_HW_RESE_TEST",1)
uvm_resource_db#(bit)::set("REG::",reg_model.reg2.get_full_name(),"NO_REG_HW_RESE_TEST",1)
uvm_resource_db#(bit)::set("REG::",reg_model.reg3.get_full_name(),"NO_REG_HW_RESE_TEST",1)
While doing this I able to observe reg1 comparison is not happening (which is supposed to be) but reg2 and reg3 comparison is happening.
Even If I changed order, first register in that order is not comparing but remaining 2 still
Can anyone help on how to resolve this issue
Sandeep
