Hi Everyone ,
i have defined single agent(UVC) and declared 10 agent objects. The each agent object have separate configuration. Now how can i use each configuration to differentiate 10 uvm_sequence_item corresponding to 10 agents.
example :
axi_agent a0,a1,a2;
data_bus width of a0 = 32 bit ;
data_bus width of a1 = 64 bit ;
data_bus width of a2 = 128 bit ;
whenever i will run a0,a1,a2 agent parallel ,the squencer of agent must pick corresponding uvm_seq-> corresponding uvm_seq_item.
How can i will get implement reusable agent , seq_item ?
very advance thanks
Regards
kbkdec15
