Hi all ,
I see that uvm_component has property " bit print_enabled = 1 ; " ( public )
When set to 0 by user , the component is skipped from print in Topology .
class env extends uvm_component;
`uvm_component_utils(env)
// Both acomp and bcomp extend uvm_component
acomp acomp_h[4];
bcomp bcomp_h;
function new(string name, uvm_component parent=null);
super.new(name,parent);
foreach(acomp_h[i])
acomp_h[i] = new($sformatf("acomp_h%0d",i),this);
bcomp_h = new("bcomp_h",this);
foreach(acomp_h[i])
acomp_h[i].print_enabled = 0 ;
bcomp_h.print_enabled = 0 ;
virtual function void start_of_simulation_phase(uvm_phase phase);
uvm_top.print_topology();
run_test("env"); // env would be uvm_test_top
Gives Output ::
UVM_INFO @ 0: reporter [RNTST] Running test env…
UVM_INFO @ 0: reporter [UVMTOP] UVM testbench topology:
Name Type Size Value
uvm_test_top env - @454
I observe that component acomp and bcomp don’t get printed .
Consider a VIP where it doesn’t want its customers to know the full Topology of its product , if they were to use this approach the end user can always know about the Topology via explicitly setting the property to 1 again !.
[Q] So is there any other way to hide the Topology from user ?
Thanks ,
TC
