isn’t it supposed to loop forever inside the body(). and because of that it will never be able to execute next sequence or loop back to start of execution?
class slave_memory_seq extends uvm_sequence #(ubus_transfer);
function new(string name="slave_memory_seq");
// `uvm_sequence_utils(slave_memory_seq, ubus_slave_sequencer)
`uvm_object_utils(slave_memory_seq)
`uvm_declare_p_sequencer(ubus_slave_sequencer)
ubus_transfer util_transfer;
int unsigned m_mem[int unsigned];
virtual task pre_do(bit is_item);
// Update the properties that are relevant to both read and write
req.size = util_transfer.size;
req.addr = util_transfer.addr;
req.read_write = util_transfer.read_write;
req.error_pos = 1000;
req.transmit_delay = 0;
req.data = new[util_transfer.size];
req.wait_state = new[util_transfer.size];
for(int unsigned i = 0 ; i < util_transfer.size ; i ++) begin
req.wait_state[i] = 2;
// For reads, populate req with the random "readback" data of the size
// requested in util_transfer
if( req.read_write == READ ) begin : READ_block
if (!m_mem.exists(util_transfer.addr + i)) begin
m_mem[util_transfer.addr + i] = $urandom;
req.data[i] = m_mem[util_transfer.addr + i];
function void post_do(uvm_sequence_item this_item);
// For writes, update the m_mem associative array
if( util_transfer.read_write == WRITE ) begin : WRITE_block
for(int unsigned i = 0 ; i < req.size ; i ++) begin : for_block
m_mem[req.addr + i] = req.data[i];
`uvm_info(get_type_name(),
$psprintf("%s MEMSEQUENCER...",
get_sequence_path()), UVM_MEDIUM);
end : for_block
virtual task body();
$psprintf("%s starting...",
$cast(req, create_item(ubus_transfer::get_type(), p_sequencer, "req"));
forever
p_sequencer.addr_ph_port.peek(util_transfer);
$sformatf("util_transfer.data = %h util_transfer.addr = %h",
util_transfer.data,util_transfer.addr), UVM_NONE);
// Need to raise/drop objection before each item because we don't want
// to be stopped in the middle of a transfer.
starting_phase.raise_objection(this);
start_item(req);
finish_item(req);
starting_phase.drop_objection(this);
endtask : body
endclass : slave_memory_seq
