I have created a interface on the design side.
module aes_agent_bfm(aes_if aif);
aes_driver_bfm driver(aif.master_mp);
//tbx vif_binding_block
import uvm_pkg::uvm_config_db;
uvm_config_db #(virtual aes_driver_bfm)::
set(null, "*", $psprintf("%m.driver"), driver);
aes_monitor_bfm monitor(aif.monitor_mp);
uvm_config_db #(virtual aes_monitor_bfm)::
set(null, "*", $sprintf("%m.monitor"), monitor);
interface aes_monitor_bfm(aes_if aif);
// pragma attribute aes_monitor_bfm partition_interface_xif
parameter int AES_RSP_NUM_BITS = $bits(aes_response_s);
parameter int AES_RSP_NUM_BYTES = (AES_RSP_NUM_BITS+7)/8;
typedef bit [AES_RSP_NUM_BITS-1:0] aes_response_vector_t;
wire clk = aif.clk;
task data_monitor(input aes_response_s rsp); //pragma tbx xtf
@(posedge clk)
$display("In the monitor vif.vip_clk.valid_out = %d", aif.valid_out);
$display("monitor_valid_out=%d", rsp.valid_out);
$display("ciphertext=%h", rsp.ciphertext);
endinterface
`ifndef ENCRYPT_ENV_SV
`define ENCRYPT_ENV_SV
`include "uvm_macros.svh";
`include "agent.sv"
class encrypt_env extends uvm_env;
`uvm_component_utils(encrypt_env)
encrypt_agent agent;
agent = encrypt_agent::type_id::create("agent", this);
uvm_config_db #(virtual aes_driver_bfm)::get(this, "", "top.aes_agent.driver", agent.driver.v_drv_bfm);
uvm_config_db #(virtual aes_monitor_bfm)::get(this, "", "top.aes_agent.monitor", agent.monitor.v_mon_bfm);
`endif
Now i am getting the following error
Virtual interface resolution cannot find a matching instance for “virtual aes_monitor_bfm”
