Hi all ,
Last few days I went through various articles / papers / UVM code study on UVM Factory and Parameterized Tests .
Have a list of questions ::
(1) String N Type based Factory ::
**run_test() requires test to be registered with string - based factory ( internally it calls factory.create_component_by_name )**
(i) I believe since run-time arguments ( via +UVM_TESTNAME=test ) are string literals , run_test() requires string - based factory .
[Q1] Am I correct with this or am I missing out on something else too ?
(ii) [Q2] Is string-based factory used in run_test() only or are there other areas where string-based factory is used ?
(2) Macro `uvm_component_param_utils doesn’t provide 2nd string argument to specialization of uvm_component_registry class .
It’s left to the user to provide 2nd argument explicitly
**[Q3] Is this because the parameterized component could have N parameters associated with it ? .
So there is no way a macro would know how many parameters are associated with the class**
(3) Factory registration is done via uvm_object_wrapper ( proxy class ) where the actual object is handle to
uvm_component_registry N uvm_object_registry .
So via call to run_test() the appropriate string based lookup is done and the precise Test Top is instantiated .
Similarly via calls to type_id::create() Type-based factory is used and the appropriate component / object is created .
My question is related to following line from UVM LRM 8.2.3 about uvm_component_registry ::
**"Without it registration would require an instance of the object itself "**
**[Q4] What does the above line mean ??**
