Dear All,
I’m trying to make a tiny simple example of systemverilog array as the below,
module test();
`include "uvm_macros.svh"
`include "uart_ctrl_regs.sv"
class test extends uvm_test;
uart_ctrl_reg_model_c reg_model;
uvm_reg regs[$];
function void build();
uvm_reg::include_coverage("*", UVM_CVR_ALL);
reg_model=uart_ctrl_reg_model_c::type_id::create("reg_model", this);
reg_model.build();
task run();
reg_model.reset();
foreach(regs[$]) begin
`uvm_info(get_type_name(), $psprintf("TEST = %s" , regs.get_name ), UVM_LOW)
`uvm_component_utils(test)
super.new(name,parent);
initial run_test("test");
class uart_ctrl_reg_model_c extends uvm_reg_block;
`uvm_object_utils(uart_ctrl_reg_model_c)
function new(input string name="unnamed-uart_ctrl_reg_model_c");
super.new(name, UVM_NO_COVERAGE);
endclass : uart_ctrl_reg_model_c
But I can’t understand the compile error message
ncvlog: *E,EXPRBK (testbench.sv,20|17): expecting a right bracket (']') [SystemVerilog foreach].
Could you please help me to understand the problem about why does it make such as error message?
