I have the following code which is not getting compiled as the pkt handle is declared and instantiated on the same line:
router_tb tb;
function new(string name = "router_tb", uvm_component parent = null);
endfunction : new
`uvm_info("%m","Build phase",UVM_HIGH)
tb = router_tb::type_id::create("tb", this);
packet pkt = new();
endfunction : build_phase
function void end_of_elaboration_phase(uvm_phase phase);
uvm_top.print_topology();
endfunction : end_of_elaboration_phase
endclass : base_test
However, if I declare the pkt class handle separately, the compilation is clean. Any background on this restriction?
