I have a performance model (perf_mon.sv) which I have instantiated inside the base test. I am generating some values inside the model and I want to pass these generated values to my sequence. For this what I am doing is that I am generating the integer in my model and setting it to the config_db and then trying to get the same inside my sequence. But I am getting the following error:
Error-[ICTTFC] Incompatible complex type usage
Incompatible complex type usage in task or function call.
The following expression is incompatible with the formal parameter of the function.
uvm_config_db#(integer)::get(this, “*”, “rvalid_delay”,
this.rvalid_delay)
This is how I am trying to get the integer value. Please give some solution for the problem.
Verilog/SV integer is 4-state and perhaps you wanted int
Assuming you are doing the ::get inside a sequence, use null as context as Sequences do not have a fixed hierarchy. Kind of a namespace in global and both set and get will use that.
