I have an issue with regards to getting a timeout to work for RTL hangs. I have implemented a small counter in the interface which on every posdege of clk, resets to max_timeout value upon reset or if it detects a output valid, otherwise decrements. In my test base. I have a task as below:
task check_end_of_simulation(int unsigned scenario_count);
// Check whether it is okay to end the simulation
wait(scenario_count == m_env.m_sys_mon.rsp_q.size());
`uvm_info({get_type_name(), ":run"},"All the responses received. Hence terminating the test",UVM_MEDIUM)
wait(inf.count == 0);
`uvm_error({get_type_name(), ":run"},"Timed out. Hence terminating the test")
join_any
endtask: check_end_of_simulation
and in every test I have something like:
// Raise objection
// randomize the vseq
// Start of virtual sequencer
// drop objection.
My virtual sequence has something like:
scenario_id = 1;
while(scenario_id <= 100) begin
drive_seq_1();
drive_seq_2();
scenario_id++
Now the problem is, after sending say, 20 scenarios the RTL hangs and the while loop never completes. That means I am never getting to the calling check_end_of_simulation() task in the test and the test runs forever.
How do I re-write my timeout mechanism to handle my requirement ? Are there any recommended ways of implementing requirements such as these, as pretty much all the verification environments need something similar to this ?
Thanks & Regards,
Madhu
