Can any one provide the solution for this problem.
My test bench completely made with UVM.So i want to access the one of the task in the sequence class from c program.
When i am tried to export the task in the class,I am getting the error like no task found.
So i placed the same task outside class,I am able to export/import the tasks from c.
Now the problem comes here with the sequence,
Here sequence can communicate with the sequencer.but when i moved the task outside the class,task can’t able to talk to the next layer tasks.
Here error is showing that sequencer is not found.
Can any one provide the solution for this type of issue.
Please provide the examples if any.
Kamesh.
