Hi I came across a very clean way of implementing a pipelined driver in this forum. Its an old post but no one chimed in to comment on the code or its feasibility. dave_59, chr_sue or anyone else care to comment on the post below?
UVM pipelined driver implementation - UVM - Verification Academy
In reply to yourcheers:
Dear Forum,
Are there any drawbacks with this kind of UVM pipelined driver implementation, compared to the one in cookbook where do_pipelined_transfer() is called twice.
In this approach, spawning a thread to drive data in a forever loop and the addr phase is executed as and when there is a sequence item from sequence, and sends the same req to data-phase forever loop to drive. Major difference is using the mailbox to send the req information to other thread, the cookbook implementation uses semaphore.
Pipelined Protocols | UVM Cookbook
class ahb_pipelined_driver extends uvm_driver#(ahb_seq_item);
`uvm_componenet_utils(ahb_pipelined_driver);
mailbox save_txn;
task run_phase();
data_phase();
join_none
drive_addr_phase(req);
seq_item_port.item_done();
task drive_addr_phase();
while(ahb_id.HREADY!=0)begin
@(posedge ahb_id.HCLK);
ahb_if.HTRAN <= NON-SEQ;
ahb_if.HBURST <= ahb_if.HBURST;
save_txn.put(req);
ahb_if.HTRAN <= IDLE;
ahb_if.HBURST <= IDLE;
task data_phase();
save_txn.get(req);
if(req.HWRITE)begin
//Drive WDATA ...
else begin
//Capture RDATA ...
seq_item_port.put_response(req);
