Could you please clarify the below. in general uvm_ analysys_port calls the write function of uvm_analysys_imp .but in the below example ABC class analysys_export is called.but it has write function also.could you please clarify whether uvm analysys also has export function.
class ABC extends uvm_subscriber #( C_item );
`uvm_component_utils( ABC )
C_agent c_agent;
function new(string name, uvm_component parent=null);
// this method connects the incoming C_items to the c2b monitor
function void write( C_item t );
c2b_mon.write( t );
// a convenience method to connect active and passive datapaths in one method
function void connect_to_C_agent( C_agent c );
c_agent = c;
c_agent.ap.connect( analysis_export );
