I want to poll or block a piece of code until a certain bit field in my register model gets updated. How would I do this?
In reply to VerifEx:
Have you even tried to read at any of the documentation?
https://verificationacademy.com/verification-methodology-reference/uvm/docs_1.1d/html/index.html
Look for needs_update() maybe you can use it for whatever you need to implement
-R
In reply to rgarcia07:
In my Knowledge there is no method indicating a register in the DUT was modified. In your case you can observe this specific register and trigger an event to start your piece of code.
He mentioned in his original post “…my register model gets updated…” not the DUT that’s why I suggested needs_update()
From the source code documentation
// Function: needs_update
// Check if the abstract model contains different desired and mirrored values.
// If a desired field value has been modified in the abstraction class
// without actually updating the field in the DUT,
// the state of the DUT (more specifically what the abstraction class
// ~thinks~ the state of the DUT is) is outdated.
// This method returns TRUE
// if the state of the field in the DUT needs to be updated
// to match the desired value.
// The mirror values or actual content of DUT field are not modified.
// Use the <uvm_reg::update()> to actually update the DUT field.
I do agree for the DUT there is not such function/task, and it could be implementing by polling backdoor or using events.
