This is related to the code examples given on Driver/Pipelined | Verification Academy
So as I understand it, the first sequence item begins with get(req) in the driver, and continues until it reaches the blocking command_phase(req) task in the BFM. One clock cycle of time will be consumed, and the next sequence item can begin and also reach this point. If the first stage of the pipeline is more than one clock cycle of simulation time, both threads will be running the first stage of the pipeline simultaneously, which doesn’t make sense. In these examples, is it assumed that each stage of the pipeline only consumes 1 clock cycle of simulation time?
Let me know if you need more clarification on my question, thanks.
