Creating virtual sequencer
Dear All,
I’m trying to understand about virtual sequencer concept I found the below links.
/code
//Create a virtual sequencer
class v_seqr extends uvm_sequencer;
uvm_sequencer#(seq_item_1) seqr1;
seqr_2 seqr2;
function new(string name=‘v_seqr’, ubm_component parent);
in the above example OP just used “class v_seqr extends uvm_sequencer;”
there is of no use to declare “virtual keyword”.
My question that how do we make virtual sequencer?
I thought that that was created such as “virtual calss v_seqr extends uvm_sequencer”.
Would you please let me know about how to create the virtual sequencer?
In reply to UVM_LOVE:
The word ‘virtual’ means that the sequencer generates no specific sequence_items. It is used only to start sub-sequences on another sequencer.
You will never see the keyword ‘virtual’ when declaring a virtual sequencer. The virtual sequencer will extend uvm_sequencer with no specialization.
Please see the UVM Cookbook.
Note that we don not recommend the use of virtual sequence**r**s, as they are not strictly necessary and can limit reuse by enforcing additional hierarchy in your environment. The link above shows how you can use virtual sequences without using a virtual sequencer. However, if you insist on using a virtual sequencer, there is a link at the bottom of the page that discusses them.
In reply to tfitz:
Thanks tfitz,
I think this is depending on the project style. if I need to handle of 300 sequencers or more , once I will make a virtual sequences library then I can use handy keyword (p_sequence) and connect to sequences. it is more handy and cost effective. What do you think ?
If you dont mind, Would you please introduce about what you recommend like it?
I believe you misunderstood tfitz. He meant you do not need a virtual sequencer, because you can start virtual sequences on a 'null’sequencer like this:
vseq.start(null);
If you want to use a virtual sequencer you can define it as you did. Any sequencer which does not itself create seq_items can be considered to be a virtual sequencer
vseq.start(null);
Regarding of your comments, I took for a while and searching it. but I can’t find about the usage of 'uvm_declare_p_sequencer(…) in the link.
So I’m confused what he saying about do not use virtual sequencer means it is or not.
Please see Advanced UVM: Layered Sequences.
Notice that nowhere do I use `uvm_declare_p_sequencer(…)
Good luck.
