Dear UVM experts,
while create a parameterized sequence object i run into this error (during Loading …):
Error: (vsim-7065) C:/modeltech64_10.5/win64/…/verilog_src/uvm-1.2/src/base/uvm_registry.svh(67): Illegal assignment to class mtiUvm.uvm_pkg::uvm_component from class work.simpleadder_pkg::simpleadder_sequence #(class work.simpleadder_pkg::simpleadder_transaction)
i tried casting just before assignment… but it seems that the error is within the create… in the return line 67.
i will appreciate any suggestion…
Y
the test class:
class simpleadder_test extends uvm_test;
typedef simpleadder_sequence#(.T(simpleadder_transaction)) sqce_t;
`uvm_component_utils(simpleadder_test)
function void simpleadder_test::build_phase(uvm_phase phase);
sa_env = simpleadder_env::type_id::create( .name(“sa_env”), .parent(this) );
sa_seq = sqce_t::type_id::create( .name(“sa_seq”), .parent(this) );
endfunction: build_phase
endclass: simpleadder_test
the sequence class:
class simpleadder_sequence#(type T=uvm_object) extends uvm_sequence#(T);
`uvm_component_param_utils(simpleadder_sequence #(T))
endclass: simpleadder_sequence
the sequencer class:
class simpleadder_sequencer#(type T=uvm_object) extends uvm_sequencer #(T);
`uvm_component_param_utils(simpleadder_sequencer #(T))
endclass: simpleadder_sequencer
