Guys,
I have cover group declared outside of class and instantiated inside the class.
Getting “Segmentation Fault Issue” when I sample the same.
covergroup cg_axi (ref axi_transaction tr, input int addr_low, int addr_high );
option.per_instance = 1;
option.get_inst_coverage = 1;
option.merge_instances = 1;
cp_id : coverpoint tr.id {
bins id[] = {[0:15]}; //0 to 15
cp_xact_type : coverpoint tr.xact_type{
bins wr = {axi_transaction::WRITE};
bins rd = {axi_transaction::READ};
cp_addr : coverpoint tr.addr {
bins addr[10] = {[addr_low : addr_high]};
cp_blen : coverpoint tr.burst_length {
bins blen[] = {[0:15]}; //1 to 16
cp_btype : coverpoint tr.burst_type {
bins btype[] = {[0:2]}; //FIXED,INCR,WRAP
cp_bsize : coverpoint tr.burst_size {
bins bsize[] = {[2:4]}; //32,64,128
endgroup
class fabric_scoreboard extends uvm_scoreboard;
axi_transaction cpu_slave_axi_tr,cpu_lpddr0_axi_tr,cpu_lpddr1_axi_tr,cpu_pcie0_axi_tr,cpu_pcie1_axi_tr,cpu_pcie2_axi_tr;
cpu_slave_axi_tr= axi_transaction::type_id::create("cpu_slave_axi_tr");
cpu_lpddr0_axi_tr= axi_transaction::type_id::create("cpu_lpddr0_axi_tr");
cpu_lpddr1_axi_tr= axi_transaction::type_id::create("cpu_lpddr1_axi_tr");
cpu_pcie0_axi_tr= axi_transaction::type_id::create("cpu_pcie0_axi_tr");
cpu_pcie1_axi_tr= axi_transaction::type_id::create("cpu_pcie1_axi_tr");
cpu_pcie2_axi_tr= axi_transaction::type_id::create("cpu_pcie2_axi_tr");
//AXI
cg_axi_cpu_slave = new(cpu_slave_axi_tr,`AXI_CPU_SLAVE_ADDR_L,`AXI_CPU_SLAVE_ADDR_H);
cg_axi_cpu_lpddr0 = new(cpu_lpddr0_axi_tr,`AXI_CPU_LPDDR0_ADDR_L,`AXI_CPU_LPDDR0_ADDR_H);
cg_axi_cpu_lpddr1 = new(cpu_lpddr1_axi_tr,`AXI_CPU_LPDDR1_ADDR_L,`AXI_CPU_LPDDR1_ADDR_H);
cg_axi_cpu_pcie0 = new(cpu_pcie0_axi_tr,`AXI_CPU_PCIE0_ADDR_L,`AXI_CPU_PCIE0_ADDR_H);
cg_axi_cpu_pcie1 = new(cpu_pcie1_axi_tr,`AXI_CPU_PCIE1_ADDR_L,`AXI_CPU_PCIE1_ADDR_H);
cg_axi_cpu_pcie2 = new(cpu_pcie2_axi_tr,`AXI_CPU_PCIE2_ADDR_L,`AXI_CPU_PCIE2_ADDR_H);
endfunction: build_phase
// AXI Slave write function
virtual function void write_axi_cpu_slave(axi_transaction tr);
axi_transaction local_tr;
local_tr = axi_transaction::type_id::create("local_tr");
local_tr.copy(tr);
case (tr.addr) inside
[`AXI_CPU_SLAVE_ADDR_L : `AXI_CPU_SLAVE_ADDR_H] : begin cpu_slave_axi_tr = local_tr; cg_axi_cpu_slave.sample(); end
[`AXI_CPU_LPDDR0_ADDR_L : `AXI_CPU_LPDDR0_ADDR_H] : begin cpu_lpddr0_axi_tr = local_tr; cg_axi_cpu_lpddr0.sample(); end
[`AXI_CPU_LPDDR1_ADDR_L : `AXI_CPU_LPDDR1_ADDR_H] : begin cpu_lpddr1_axi_tr = local_tr; cg_axi_cpu_lpddr1.sample(); end
[`AXI_CPU_PCIE0_ADDR_L : `AXI_CPU_PCIE0_ADDR_H] : begin cpu_pcie0_axi_tr = local_tr; cg_axi_cpu_pcie0.sample(); end
[`AXI_CPU_PCIE1_ADDR_L : `AXI_CPU_PCIE1_ADDR_H] : begin cpu_pcie1_axi_tr = local_tr; cg_axi_cpu_pcie1.sample(); end
[`AXI_CPU_PCIE2_ADDR_L : `AXI_CPU_PCIE2_ADDR_H] : begin cpu_pcie2_axi_tr = local_tr; cg_axi_cpu_pcie2.sample(); end
endcase
endfunction: write_axi_cpu_slave
Please check and confirm that is there any issue on my code?
John
