I tried to use clone method to copy req-rsp but it seems to be failing. I tried to display rsp.data_in but prints '0 all time. req.data_in is getting correct values.
Can someone point out what I am missing.
//driver class main_phase
pkt_seq_item req;
pkt_seq_item rsp;
forever
if(!$cast(rsp, req.clone())) `uvm_fatal("my_driver", "failed to clone");
rsp.set_id_info(req);
`uvm_info(get_type_name(),$sformatf("rsp.data_in %d",rsp.data_in),UVM_LOW);
@(posedge vif.clk);
if(req.write)begin
vif.data_in = req.data_in;
vif.write = req.write;
repeat(5)@(posedge vif.clk);
rsp.data_out = vif.data_out;
seq_item_port.item_done(rsp);
endtask: run_phase
