Hi there,
Does anyone have idea how we can link the setting of UVM Report Message to the mode that we are running? For example, in the interactive/debug mode run, we would the Verbosity is DEBUG, but for regression mode, we would the Verbosity is LOW …
Thanks!
UVM provides two ways of controlling the verbosity:
- Verbosity command line switches
vsim testbench +UVM_VERBOSITY=UVM_HIGH
- Verbosity method calls
set_report_id_verbosity_hier
set_report_severity_id_verbosity_hier
Both these ways don’t help your requirement to link the verbosity control to the simulation mode. UVM is simulation tool agnostic. It seems like, you might have to create a wrapper script to run your tests in interactive or non-interactive mode, and chose the verbosity accordingly. For regression mode, you can always make it a point to embed the appropriate verbosity in the regression script. For a single-run case, you can write a script, similar to one shown below.
Script:
#! /bin/csh -f
set var = $1
if ($1==interactive)
vsim testbench +UVM_VERBOSITY=UVM_DEBUG
else
vsim testbench +UVM_VERBOSITY=UVM_NONE
endif
