can the rtl file generated by the reg tool be simulated?
thanks
In reply to qais:
I’m not exactly sure what your question is. Any RTL whether it’s manually written or automatically generated should be simulatable. If you trust the too it should not be necessary to verify the generated code, but you do need to verify that it’s been correctly connected into the DUT.
