Hi I have a UVM environment where a class looks at the transaction and does some modelling.
From this class, i want to call verilog code which also does some modelling in parallel. Both modelling are not related.
How to do this?
In reply to jyotsna:
Not sure what exactly you mean by the word “modeling” but I assume that some other Verilog code will need to be run.
The only mechanism that I am aware of is DPI-C. You will have to come up with “C” routines that can get called from your objects (say xyz_driver) and these “C” routines can in turn call a DPI-C exported task or function.
Hope this helps… but if you need more detail please provide more context
In reply to logie:
I’m not sure this needs to involve C code, but you definitely need to be clearer on what kind of Verilog code you need to call. If you mean tasks of a bus-functional model written in a verilog module, you can use the abstract/concrete class mechanism similar to what I wrote in my DVCon paper.
To give the context, i have a class which monitors the transaction and does some checks.
Some of these checks are present in verilog code also so i wanted to use these checks(remove duplicacy) and call them whenever a transaction is seen.
If these checks are written ss Verilog tasks, then my DVCon paper outlines the approach you should take.
For some history, you might want to read OVM wrapper for Verilog Bfms?? | Verification Academy
