Hello !
Would like to know if there is any best scalable flow to verify dsp-matlab based reference model flow.
- We usually we wrap around any Matlab based reference model inside a C-Wrapper.
- And these reference model is being called directly inside the scoreboard using DPI Calls.
- Then we constraint randomize the configuration/setup and apply them to both reference model and also the RTL.
- We will be feeding in the required stream of inputs to be processed to both reference Model and the RTL and cross validate the expected output b/w RTL & reference model.
But is there any other way that industry follows or any known best practises / flow that you might have come across to validate such scenarios. Please share in your comments.
Regards !
