I have a 15-bit register in UVM based register model, to which I am writing 15’h7fff. The automatic bins getting generated for the register are as follows:
In waveform, I can see 15 bits of register are getting written, but where as bins are concerned, out of these 4 bins, only 1 bin “auto[0:8191]” is getting hit.
Can anybody explain the reason for the same? Let me know, if need more details.
Could you please explain how your coverpoint looks like. If you let the simulator automatically generate the bins you get more then only 4 for a 15 bit variable.
In reply to kmishra:
What i understand is, since the bins got generated automatically from register model, it got broken bins into 4. 2 raise to power 15 is 32768. I am using vManager for coverage and to me, it’s showing these 4 bins only.
I do not see how you are sampling the covergroup. The issue might be there. The definition of your covergroup might be also of interest (including the sample method).
