Hi, I wanted to know if get_next_item() and item_done()were in built methods of the uvm_seq_item_pull_port class?
From the cookbook: “The API used by driver code to interact with the sequencer is referenced by the seq_item_port, but is actually implemented in the sequencers seq_item_export (this is standard TLM practice).”
I am confused as to what “implementation” is defined in the sequencers seq_item_export? And by “sequencers seq_item_export”, do they mean the receiving component?
