How do you implement this scenario in UVM Testbench ?
Assuming, UVM environment has 3 different agents having scope to their own interfaces.
On driving wrong stimuli on agent1, there will be error pin asserted on interface3
monitor of agent2 sees this). Soon after error-pin assertion, there should be a read transaction from agent2.
How do you make sure your agent2 drives a read transaction on every wrong stimulus from agent1?
In reply to dvuvmsv:
if your agent2 is not implemented as reactive agent then you will have to add uvm_event in monitor to generate the event(event.trigger()). and your sequence will be running in forever loop ,will be blocked by the event.wait_trigger() function. whenever the sequence see the event it will automatically start executing read_sequence on agent2
Thanks for your reply.
I think in the agent2 monitor run_phase, I should add the code to wait for the error on signal and create the event as you mentioned. I believe the agent2 driver should sample the event
like env.agent2.mon.event.wait_trigger() and start the read sequence.
If you can give an example code that would be great.
