Writing configuration data to a file using simulator1 and reading the configuration data from the file using simulator2
*In reply to chr_sue:
Thanks chr_sue for your observation.
Also I modified the code with some changes for uvm_printer to uvm_default_printer and now it works -
function void display_config() ;
 uvm_default_printer.knobs.mcd = $fopen("CONFIG_OVERRIDE_FILE.txt"); // opening the file
 this.print();
 $fclose(uvm_default_printer.knobs.mcd); // closing the file
Still the question about reading the configuration remains unanswered. Any suggestions ?
