Why void casting when randomizing class variables?
In reply to jh_veryveri:
  1. Casting the return value of a function to void explicitly tells the compiler / simulator that you are discarding the value. Some compilers / simulators may throw a warning if it’s not cast to void.
  2. You should always check the return value of randomize, even on “obvious” randomizations that you know can’t fail. A macro can help make things easier.
