I have some difficulty to bring up a simple DPI-C example.
The compiler error message like this:
Error-[DPI-DXCWOS] DPI export call with NULL scope
DPI export function/task “wait_clock” is illegally invoked (instead of from
an import function) from user/external C/C++ code, and thus has NULL scope.
Please check if the export function is called from an import function, or
the scope is properly set via ‘svSetScope’.
write(): addr:0x4, data:0x3e3a2000
1.Is there some wrong by declaring a function called write() in C?
2. Why test_func() didn’t invoke correctly, but write() get invoked? If there any way to add some CFLAGs to let C Compiler(gcc) to detect this type of error?
import "DPI-C" context task test_func();
export "DPI-C" task wait_clock;
bit clk = 0;
always #5 clk = ~clk;
task wait_clock();
@(posedge clk);
int result;
#10;
test_func();
#include <stdio.h>
#include "svdpi.h"
extern void wait_clock(void);
extern void write(int addr, int data);
extern int test_func(void);
void write(int addr, int data) {
printf("write(): addr:0x%0x, data:0x%0x\n", addr, data);
//add delay to mimic the actual write on SV side
wait_clock();
printf("write(): complete.\n");
int test_func(void) {
printf("Calling wait_clock from C...\n");
wait_clock();
printf("Returned from wait_clock.\n");
return 0;
The same rules that prohibit a function from calling a task in SystemVerilog also apply to C routines that use the DPI. In this case, you must import test_func as a task, rather than a function.
The assignment statement result = test_func(); if the RHS consumed time.
Thank, Dave. That’s helpful. The function, task imported from C is strictly checked in SystemVerilog, but C only have function. Now the Error message sounds clear to me.
That is fast reply, Dave. I have add another function in C side, declare write(), which is called inside test_func(). However, test_func is not invoked in the first place. Instead, write() is invoked. It seems write() is a reserved function in DPI-C. I am not sure that can be exploited to inject some unintended code. That is completely different topic.
Here I am more curious is there any way to avoid the C domain function naming, and is there any flags can be add to GCC to detect this issue ahead?
