I am trying to write coverage for my design, wherein I have used cross coverage between two coverpoints.
But i don’t get why am I getting this syntax error.
I hope this is the correct way to implement::
FIFO_FULL_CROSSED_WITH_FIFO_PUSH: cross tx.full, tx.wr
illegal_bins zz = binsof(FIFO_FULL.full) && binsof(WRITE.wr);
full and write are variables inside the sequence_item “tx”.
FIFO_FULL and WRITE are the names of coverpoints.
When I run this code in my UVM environment I get this error::
Error-[SE] Syntax error
Illegal identfier in binsof expression. Coverpoint identifier used
in this cross is expected.
"coverage_collector.sv", 43: token is ')'
