Hi all,
I’m working on a Verilog/SystemVerilog task that rearranges bits from a 312-bit word into a new 312-bit format using 8-bit temporary storage (temp[39]). Below is a simplified version of my code:
`define NUM_OF_BANK_LINES (1024*3)
`define RAM_MODEL_DEPTH 1024
module test;
reg i_CLK = 0;
reg [311:0] RAM_BANK_LO[`RAM_MODEL_DEPTH * 3];
reg [311:0] MY_RAM_BANK_LO[`RAM_MODEL_DEPTH * 3];
int i, j;
always #(1.25) i_CLK = ~i_CLK;
task mem_task(
input [311:0] IN_MEM_BANK [`NUM_OF_BANK_LINES],
output reg [311:0] OUT_MEM_BANK [`NUM_OF_BANK_LINES]
reg [7:0] temp[39];
for (int row = 0; row < `NUM_OF_BANK_LINES; row++) begin
for (int loc = 0; loc < 39; loc++) begin
temp[loc][0] = IN_MEM_BANK[row][39*0 + loc];
temp[loc][1] = IN_MEM_BANK[row][39*1 + loc];
temp[loc][2] = IN_MEM_BANK[row][39*2 + loc];
temp[loc][3] = IN_MEM_BANK[row][39*3 + loc];
temp[loc][4] = IN_MEM_BANK[row][39*4 + loc];
temp[loc][5] = IN_MEM_BANK[row][39*5 + loc];
temp[loc][6] = IN_MEM_BANK[row][39*6 + loc];
temp[loc][7] = IN_MEM_BANK[row][39*7 + loc];
OUT_MEM_BANK[row] = {
temp[38], temp[37], temp[36], temp[35], temp[34], temp[33],
temp[32], temp[31], temp[30], temp[29], temp[28], temp[27],
temp[26], temp[25], temp[24], temp[23], temp[22], temp[21],
temp[20], temp[19], temp[18], temp[17], temp[16], temp[15],
temp[14], temp[13], temp[12], temp[11], temp[10], temp[9],
temp[8], temp[7], temp[6], temp[5], temp[4], temp[3],
temp[2], temp[1], temp[0]
for (j = 0; j < 39; j++)
$display("temp[%0d] = %0h", j, temp[j]);
$display("OUT_MEM_BANK[%0d] = %0h", row, OUT_MEM_BANK[row]);
for (i = 0; i < 1000; i++) begin
RAM_BANK_LO[i] = i;
mem_task(RAM_BANK_LO, MY_RAM_BANK_LO);
The problem:
When temp[0] = 1 and temp[1] = 1, and all other temp[2] to temp[38] are zero, I expect:
OUT_MEM_BANK[3] = 8'b00000011 = 0x03
However, what I actually get is:
OUT_MEM_BANK[3] = 0x65 (decimal 101)
Question:
Why am I seeing OUT_MEM_BANK[3] = 101 instead of 0x03, even though only temp[0] and temp[1] are 1?
Additional Info:
OUT_MEM_BANKis a 312-bit vector.- It seems like only the LSB of each
temp[x]is being assigned, but I’m not explicitly zeroing out upper bits. Could that be the cause?
For helping to understand my problem I attached a link
