I am providing transaction as GREEN and green_signal_enable == 1.
In the above case ignore_green should not be generated in coverage report but it is generating it.
Below Code is ran in vcs_2014.03-2.
colour_type : coverpoint cov_item.colour_type iff(cov_colour_type_flag){
bins red = {transaction::RED};
bins green = {transaction::GREEN};
bins yellow = {transaction::YELLOW};
ignore_bins ignore_green = {transaction::GREEN} iff(config.green_signal_enable == 0);
option.weight = 0;
Please suggest where I am wrong,how can I solve this ignore_bins.
Naveen
The iff construct used in a covergroup is only a sampling filter - it does not affect the construction of bins. Technically, an ignore_bin is never sampled so the iff construct would have no effect, but some tools do count the ignore_bin for debugging purposes.
A better option would be to use a new 1800-2012 feature for programmable bin construction as explained in this blog.
A suggestion based on your example is:
typedef enum {BLACK, RED, GREEN, YELLOW } colour_e;
colour_e colour_type, enabled_colours[$];
covergroup ct_cg;
coverpoint colour_type {
bins colours[] = enabled_colours;
endgroup
ct_cg ct;
bit enable_green = 0;
enabled_colours.push_back(RED);
if (enable_green) enabled_colours.push_back(GREEN);
enabled_colours.push_back(YELLOW);
ct = new();
ct.sample();
colour_type = RED;
ct.sample();
colour_type = GREEN;
ct.sample();
colour_type = YELLOW;
ct.sample();
