Hi, I met a weird question.
I used 12 bits interface connect to 8 bits output of DUT, and the 8 bits initial to zero.
So it does make sense that the dut_if.test_signal value is X00 (hex).
However, when I use display function to show the data, display function change the variable value ? and the dut_if.test_signal value is changed to 000 (hex).
The residual 4 bits is modified to 0!
Personally, the display function shouldn’t modify the variable value, But it does.
I did a simple example as below, and compile it with xrun (Cadence Tool),
By the way, when I used the vcs (Synopsys) to compile it, the residual 4 bits is padding to zero in the beginning even if no display function.
interface dut_io;
bit clk;
logic [11:0] test_signal;
endinterface: dut_io
module dut(clk, test_signal);
input clk;
output reg[7:0] test_signal;
initial begin: set_data
test_signal = '0;
endmodule: dut
dut_io dut_if();
dut dut1(.clk(dut_if.clk), .test_signal(dut_if.test_signal));
initial begin: clock
forever begin
#10;
dut_if.clk = ~dut_if.clk;
end: clock
initial begin: fsdb
$fsdbDumpfile("unknown.fsdb");
$fsdbDumpvars(0, top, "+all");
end: fsdb
initial begin: testblock
#200;
// if use display, the dut_if.test_signal change from x00 to 000 (xrun)
// $display("signal: %x", dut_if.test_signal);
$finish;
end: testblock
endmodule: top
