Why do we need virtual interfaces in system verilog?
In reply to mallick1:
I can’t easily locate where in 1800 those rules are defined. However, with 2 separate simulators, I get the same errors for the following code:
module ld_reg #(SIZE=8)
    (input logic clk, ld,
     input logic[SIZE-1:0] d_in,
     output logic[SIZE-1:0] r_out, d_out,k_out,
     inout logic[SIZE-1:0] data1, data2, data3);
    logic a, b=1'b1, oe; // local variable
    wire[SIZE-1:0] wdata1, wdata2, wdata3;
    always @ (posedge clk) begin : FF_LD
        // The begin statement is only needed
        // if multiple statements in body of always
        r_out <= d_in;
        data3 <= d_in; // **** illegal LINE 13
        // line above:  A net is not a legal lvalue in this context
        // wdata1 = d_in; // illegal
        //assign wdata3 = 'bZ; // illegal
        assign d_out=oe ? 8'b101_1110 : 'bZ;
    end : FF_LD
    task is_illegal;
      @ (posedge clk)
        data1 <= d_in; // **** Illegal reference to net "data1". line 23
        wdata1 <= d_in; // Illegal reference to net "wdata1".
    // assign data1 = oe ? 8'b101_0000 : 'bZ;
    assign k_out=8'b10X_XZZ0;
endmodule : ld_reg
// COMPILATION RESULTS:
# ** Error: ld_reg.sv(13):   Illegal reference to net "data3".
# ** Error: ld_reg.sv(23):   Illegal reference to net "data1".
# ** Error: ld_reg.sv(24):   Illegal reference to net "wdata1".
Ben
