Why do we need virtual interfaces in system verilog?
In reply to mallick1:
I disagree with your statement "you can easily drive a module wire from within a task member of a class as follows
task drive();
   @(posedge clk)
      dut.signal <= 1;
Below is an example from my SVA book on verifying assertions. See the task is_illegal;
module ld_reg #(SIZE=8)
    (input logic clk, ld,
     input logic[SIZE-1:0] d_in,
     output logic[SIZE-1:0] r_out, d_out,k_out,
     inout logic[SIZE-1:0] data1, data2, data3);
    logic a, b=1'b1, oe; // local variable
    wire[SIZE-1:0] wdata1, wdata2, wdata3;
    always @ (posedge clk) begin : FF_LD
        // The begin statement is only needed
        // if multiple statements in body of always
        r_out <= d_in;
        // data1 <= d_in; // illegal
        // line above:  A net is not a legal lvalue in this context
        // wdata1 = d_in; // illegal
        //assign wdata3 = 'bZ; // illegal
        assign d_out=oe ? 8'b101_1110 : 'bZ;
    end : FF_LD
    task is_illegal;
      @ (posedge clk)
        data1 <= d_in; // Illegal reference to net "data1".
        wdata1 <= d_in; // Illegal reference to net "wdata1".
    assign data1 = oe ? 8'b101_0000 : 'bZ;
    assign k_out=8'b10X_XZZ0;
endmodule : ld_reg
I explain in the book the following:
Assignments to inout port or module wire:
  1. Module ports defined as direction inout and internal nets (e.g., wire) can be driven by the continuous “assign” statement inside a module or interface. For example:
    assign data1 = oe ? 8’b101_0000 : 'bZ; // 
    However, the assign onto nets within an always block or task is illegal:
    2)Module ports defined as direction output, inout, and internal nets (e.g., wire) can be driven by a clocking block.
  • SystemVerilog Assertions Handbook 4th Edition, 2016 ISBN 978-1518681448
