In reply to lagnaray:
Created the simple example that uses is_active from uvm_config_db. You can use this example and try to match with yours.
import uvm_pkg::*;
`include "uvm_macros.svh"
module top ;
run_test("test");
uvm_config_db#(int)::set(uvm_root::get(),"*","is_active",UVM_PASSIVE);
typedef class agent ;
class env extends uvm_env ;
`uvm_component_utils(env)
agent agt;
function new (string name="env",uvm_component parent);
super.new(name,parent);
super.build_phase(phase);
agt = agent::type_id::create("agt",this);
class agent extends uvm_agent ;
`uvm_component_utils(agent)
uvm_active_passive_enum is_active ;
function new (string name="agent",uvm_component parent);
super.connect_phase(phase);
if(uvm_config_db#(int)::get(this,"","is_active",is_active))
$display("%s",is_active.name());
if(is_active == UVM_PASSIVE)
$display("agent is in passive mode");
class test extends uvm_test ;
`uvm_component_utils(test)
env ev ;
function new (string name="test",uvm_component parent);
ev = env::type_id::create("ev",this);
output :
UVM_INFO @ 0: reporter [RNTST] Running test test…
UVM_PASSIVE
