In reply to dddvlsique:
RO reg means you cannot write this reg using standard frontdoor access that means you should test that the write doesn’t go through or eventually returns an error response. Hence I suggested to read bkdoor and write frontdoor. The usage of bkdoor helps you to speed up sim since you do not wait for protocol cycles while reading
