Hello,
If ‘provide_responses’ is 1, bus2reg would be called after getting response else bus2reg would be called as soon as finish_item is done.
See below snippet from UVM src code.
if (adapter.provides_responses) begin
uvm_sequence_item bus_rsp;
uvm_access_e op;
// TODO: need to test for right trans type, if not put back in q
rw.parent.get_base_response(bus_rsp);
adapter.bus2reg(bus_rsp,rw_access);
else begin
adapter.bus2reg(bus_req,rw_access);
Regards,
Vinay Jain
