What are the guidelines on using uvm_config_db::get() calls inside a uvm_object
In reply to Venkatesh Maddibande Sheshadrivasan:
I believe it is not a good idea to employ the command line processor for running the standard verification like regressions. This adds additional effort to maintain and archive simulator command lines. I consider the options from the command line as very useful during the testbench/sequence development to try out/modify something.
