In reply to jh_veryveri:
First you should explain what not working means and what kind of error you are getting
I assume your problem is A_valid_width as stated in the LRM is should be a constant expression or a parameter, which is different from a const variable, you could try doing a masking, I think there are plenty of examples in this forum.
11.4.12.1 Replication operator A replication operator (also called a multiple concatenation) is expressed by a concatenation preceded by a non-negative, non-x, and non-z constant expre
HTH,
-R
