Weighted constraint
hello,
i am using weighted constraint for generation arith only for two times.
but as per expectation it is not coming sometimes 3 or 5 or zero times arith value is comming
below is my code.
class alu_trans_c;
  typedef enum {LOGIC,ARITH, SHIFT} operation;
  rand logic [3:0] alu_sel_in;
 rand operation rand_oper;
// Apply following constraints
  constraint t1 {rand_oper dist {ARITH :=2,LOGIC:=3,SHIFT:=5};
                 rand_oper==LOGIC ->alu_sel_in inside {[0:5]};
                 rand_oper==ARITH ->alu_sel_in inside {[6:9]};                   rand_oper==SHIFT ->alu_sel_in inside {[10:15]};}
   $display("random values for %d are : %0d",rand_oper,alu_sel_in);
 alu_trans_c al;
 module test_random;
 initial
 al=new();
 repeat(10)
 assert(al. randomize( ));
Please format your code making your code easier for others to read. I have done that for you.
Can you please try this.
constraint t1 {rand_oper dist {LOGIC:= 3, ARITH := 2, SHIFT:= 5};
