The variable m_sequencer is the generic handle (of type uvm_sequencer parameterized with the sequence_item type) to the sequencer that the sequence is running on. The variable p_sequencer is the handle to the actual sequencer.
You should never use p_sequencer as it removes flexibility in your environment. Instead, you should add any required data elements to the sequence itself.
For agent specific sequencers, they should be declared as a typedef with the required sequence_item. Virtual sequences should always run on the ‘null’ sequencer.
