Virtual Interface Issue !?!?
When I use as below… it doesn’t work.
modeul mem_top;
	// start the test
		uvm_config_db#(virtual mem_if)::set(null, "mem_top", "memif", memif);
		run_test();
		//#1000 $finish;
This too doesn’t work.
modeul mem_top;
	// start the test
		uvm_config_db#(virtual mem_if)::set(uvm_root::get(), "mem_top", "memif", memif);
		run_test();
		//#1000 $finish;
When I use as below, it works… explain me why do we need to use wild matching “*”?
Confused with config databaase… how this matching works??
modeul mem_top;
	// start the test
		uvm_config_db#(virtual mem_if)::set(uvm_root::get(), "*", "memif", memif);
		run_test();
		//#1000 $finish;
John
