Verifying all address locations of memory
Hi All,
If I have a (address 32 bits wide) for a dual port RAM, what verification strategies are used to verify the entire memory space? Of course, we heavily rely on randomization of the address. But that does not ensure ALL address locations are verified.
What verification strategies are adopted to ensure all address locations of a large memory is thoroughly verified?
Great question! Consider looking for answers in AI websites as a starter.
I liked the response from https://g.co/gemini/share/f9d8ca375856
You’re right, relying solely on randomization for verification with a large memory space won’t guarantee all addresses are hit. Here are some strategies to ensure thorough verification of a dual port RAM with a 32-bit address space:
1. Directed Tests with Randomization:
  • Combine randomization with targeted tests. Randomize a portion of the address while fixing specific bits to target corner cases.
  • For example, randomize all but the most significant bit (MSB) to verify behavior at the boundaries of the memory space (address 0 and the maximum address).
  • Randomize all but a few lower-order bits to focus on specific memory locations or regions.
2. Pseudo-Random Techniques:
  • Utilize techniques like Linear Feedback Shift Registers (LFSRs) to generate a sequence of addresses that have good statistical properties for covering the address space. LFSRs produce a deterministic but non-repeating sequence that hits various address combinations.
3. Coverage Groups:
  • Define coverage groups that target specific functionalities of the RAM.
  • Each group can have its own set of verification scenarios with randomized addresses to ensure all aspects of the memory access are verified (e.g., read/write operations, boundary conditions, byte vs. word access).
4. Verification IP (VIP):
  • Consider using dedicated Verification IP (VIP) cores designed for memory verification. These cores provide pre-built scenarios and functionalities to automate testing and achieve high coverage.
5. Constrained Random Verification (CRV):
  • Implement Constrained Random Verification (CRV) techniques. CRV allows you to define constraints on the address randomization process. You can specify ranges, patterns, or specific values to ensure certain address combinations are included in the verification process.
Remember, achieving 100% coverage might not be practical or even necessary depending on the memory size and application. However, by using a combination of these strategies, you can significantly increase the confidence in the functionality of the dual port RAM and ensure all essential address locations are thoroughly tested.
BTW, perplexity.ai gave an interesting answer too.
https://www.perplexity.ai/search/If-I-have-SwjXIAZqTcKLAE1v4MZhmw
