Thank you for the clear explanation .
I have a final question to end this post .
// Code 3
class Base ;
rand bit [1:0] a ;
constraint aa { a == 0 ; }
class Ext1 extends Base;
rand bit [1:0] a;
constraint bb { a == 1 ; }
class Ext2 extends Ext1;
rand bit [1:0] a;
constraint cc { a == 2 ; }
// Override gparent Constraint aa
constraint aa { Base::a == 2 ; }
// Override parent Constraint bb
constraint bb { Ext1::a == 2 ; }
Ext2 e2;
e2 = new();
if ( e2.randomize() )
$display("Success with %p ",e2 );
O/P is :: Success with ‘{super:’{super:'{a:'h2}, a:'h2}, a:'h2}
Class Scope resolution operator helps to unambiguously refer to correct variable even though none are static
However if I try to constraint via in-line Constraint ::
// Code 4
class Base ;
rand bit [1:0] a ;
constraint aa { a > 0 ; }
rand bit [1:0] a;
constraint bb { a > 1 ; }
rand bit [1:0] a;
Ext2 e2;
e2 = new();
// TO_DO :: Below in-line Constraint throws Compilation Error !!
// Why does the Class Scope Resolution Operator work in Constraint Override but doesn't work within in-line Constraint
if ( e2.randomize() with { Ext1::a == 2 ; Base::a == 2 ; } ) // Valid ??
**Since unrestricted Constraint block searches for variables in Class Object Scope first ,
shouldn’t this be considered a Valid Syntax ( even though these are non-static variables ) ??
