Hi Dave ,
Code 2 is addition from Ahmed Yehia’s Paper on Randomization .
**Object of class B will have 2 properties named ‘a’ .
I understand that Code 2 isn’t a correct Coding practice .
The intention is to try out various code to understand the LRM better .**
If I modify Code2 above to ::
B b1;
b1 = new();
if ( b1.randomize() with {super.a == 3 ;} )
$display("Success with %p ",b1 );
This works and it basically constraints the property ‘a’ inherited by class B to value 3
The Output would now be ::
Success with ‘{super:’{a:3}, a:2}
The 2nd ‘a’ has no constraint ( i.e any value b/w 0 to 3 )
With the modified code , how is that super::a works within an inline-constraint but
doesn’t work as an argument to randomize() method ?
As super.a is considered a variable , isn’t it considered a Valid argument to randomize() based on LRM ??
