UVM1.2 : uvm_traversal.svh giving uvm_component name constraint warning
In reply to pk_94:
You have a semi-colon in the name of your component. This function is checking that your component name consists of an allowable character set, of which the semi-colon is not a member of. If you remove the semi-colon from your name, the error will go away.
