When setting constraint for uvm_reg_field.value, should I specify the part select? since its type uvm_reg_data_t is a 64 bits unsigned variable.
For example, if the bit width of a field is only 3 bits, and I want to constraint it to be larger than 0.
Should I use field.value > 0 or field.value[2:0] > 0?
Will the former yield a random value like 64’h1234567812345670 which the 3 lsb are 0 which I don’t want?
